Read the Issue: Click for the full digital edition of the October 2015 issue.
Talladega Pattern's Plunge Into Automation:
A small green sand nonferrous job shop answered the pull of customer demand with its first automatic molding line and sand system.
Fall River Foundry Packs One-Two Punch:
The brass caster wanted to add a second automated pouring line but first needed to improve its sand system. Now, after a two-year, $4-million investment, the facility has revamped its sand and molding operations.
Material Handling: Go With Flow:
Every metalcasting facility is unique, but a department-by-department examination may highlight ways to improve operations and reduce costs.
Flexibility and Automation in Small Metalcasting Facilities:
Two case studies illustrate how automation can be implemented in a small metalcasting facility in order to react to today's global manufacturing demands for quickly delivered customized parts.
Testing 1-2-3: New As-Cast Ductile Iron Raises Bar for Properties:
Researchers are developing ductile iron that features properties similar to ADI without heat treatment.
Issue Date
