Read the Issue: Click for the full digital edition of the April 2023 issue.
Wisconsin Precision Invested in Growth:
With open capacity available due to a plant acquisition and product obsolescence, this investment casting business took advantage of a changing market to achieve
significant growth in 2022.
The Big 6 of Aluminum Heat Treat:
Expert Jon Dossett breaks down the major factors to master if you want to succeed in heat treating aluminum castings—but he’ll tell you right out the gate,
it all boils down to temperature.
Lighter, Hotter, Stiffer ... and Cheaper: How Alloy R&D Is Working to Meet Cas…:
Three metallurgic experts discuss how the most urgent property needs are being solved.
The Effect of Firing Temperature and Time on Silica-based Investment Shell Stre…:
The study found that shell strength is significantly controlled by the degree of sintering, transformation, and particle growth.
Reconfigurable Robotic Solution for Effective Finishing of Complex Surfaces:
In European H2020 Project SYMPLEXITY “Symbiotic Human-Robot Solutions for Complex Surface Finishing Operations,” researchers developed a CNC-machine-based machining concept comprising a composition of different finishing technologies.
EDITORIAL:
Magical Metal
WASHINGTON ALERT:
EPA Budget Increase Request Highlights Policy Priorities
COLLEGE CONNECTION:
Foundry Is the Career of Choice for Gen X and Gen Z
Issue Date
