Why Lost Foam?
Marshall Miller
The use of foam patterns in metalcasting first began in 1958. While it is not as widely used as other processes like bonded sand, permanent mold or diecasting, lost foam casting provides advantages for casting intricate patterns using precision molding tools or totally patternless castings from machined foam patterns that are not feasible with other processes. A lost foam casting cell has a relatively small manufacturing footprint and could serve as a supplementary process to a foundry’s main casting operations.
The ability to offer lost foam casting could provide entry to new markets. Designing for other casting processes, such as sand casting, has restrictions. Because most casting methods require reusable patterns that must be withdrawn from the mold prior to casting, the removal of the pattern from the mold must be taken into consideration when planning the pattern layout. Conversely, using foam patterns that remain in the mold during casting and then evaporate helps reduce some of these limitations.
In the lost foam casting process, polystyrene or co-polymer beads are expanded in an aluminum tool and bonded together to form complete patterns or sections that are assembled into a foam pattern. These pieces are then glued together to form a replica of the final cast component to be made. This foam pattern with rigging is then coated with a refractory, placed in a flask and surrounded in unbonded sand and compacted. Molten metal is poured onto the foam pattern, evaporating the foam and forming the part.
With lost foam assemblies, major opportunities for mass reduction, cast-in inserts and component integration are offered. Further, metalcasters can cast components with complex shapes unthinkable in other processes. For instance, engineers can create designs with little to no draft and it is common to see uniform wall thicknesses and excellent surface finish on the end product.
Although the lost foam process may be more expensive than other casting methods, it leads to reduced costs over time, as extra labor in casting and machining processes is eliminated, as is the cost for tooling.
Advantages
The lost foam process holds unique advantages over other manufacturing and casting processes.
The freedom to design complex internal passages that are impossible or not easily manufactured in other processes is a primary advantage guiding customers to select the lost foam process. It is useful for part consolidation and the elimination of finishing and machining steps.
In the case of an iron stalk roll for 360 Yield Center, lost foam casting process was the only option (Fig. 1). This component features backdrafted teeth that come to tiny points. The teeth also have a small cup under the backside. The casting supplier made prototypes using a cut foam process where it had foams and patterns machined out of foam billet and used for test castings just to prove they could cast the product.
However, lost foam castings do not have to be complex to be successful. For example, one part for an oil drain was relatively simple. Originally made with green sand molds and a core used to make the vents, the component ran into issues during machining, when the vents were obliterated. It was a part with a high scrap rate. Converting it to lost foam casting eliminated the issue and was less expensive than the green sand cast part.
Beyond the design advantages, lost foam has process advantages, as well. The typical lost foam casting line is usually about 100 feet long. It’s a compact, usually highly automated process that has the capability of single part flow. Plus, process control is simpler. However, some of the largest lost foam foundries in the world were able to design and construct their own systems that are incredibly simple but effective.
Benchmarked vs. sand casting, lost foam achieves energy savings, improved labor productivity, material reduction, reduced stock, reduced scrap, and improved safety. Lost foam tooling can last 400,000-750,000 cycles. In iron lost foam foundries, four-week lead times are normal since patterns can be stored for months and clustered when needed. Core and mold manufacturing do not have to occur ahead of time.
The process advantages lead to cost savings. Lost foam tooling has an extremely long life, labor costs are lower, and the aggregate used is easily recycled and lends itself to ready adoption of synthetic aggregate, thus eliminating silica issues. Waste disposal is inexpensive and clean. Finishing costs are reduced with the major effort being gaging, and lower capital cost is required. It’s a high-productivity process with lower energy consumption and higher yield.
Quality improvements include no binder-related defects, long-term repeatability, no core defects, no mold shift, close dimensional tolerances, excellent surface finish and improved pressure tight castings.
Tackling the Cost of Tooling
One of the negatives about lost foam is the cost of the tools. The automotive industry has used the lost foam process heavily at high volumes, and those companies are less sensitive to tooling costs. However, the average customer is put off by the high upfront tooling cost. A curent research project funded by AFS is exploring how to reduce the cost of a tool to compete with a typical matchplate automated sand casting line. First cut tests of 3D printed aluminum molds yielded a functional tool at half the manufacturing cost. Now, AFS is funding printed titanium tools to create a lost foam tool that is expected to eliminate stress cracking and corrosion cracking.
The project entails producing and testing printed lost foam molds and expanding patterns. First, the project examined laser-printed aluminum tools using a 12 x 15 in. piece. Based on preliminary results, it appears that using an additively manufactured tool would reduce the cost about 50% (Fig. 2).
Taking the project a step further, the research team used software to redesign the tool and reduce the thickness of the tool by half. They added ribbing on the back for strength. There were no negative issues in the pattern molding process.
The same software also was used to maximize heat transfer and reduce cycle time. The target is to halve the typical cycle time. Simulations were run to ensure strength was not lost. Titanium tools are now under design for printing.
AFS is also jointly developing printed lost foam polymer tools in various materials. The effort is to produce functional tools at 25% of the cost of conventional tools. This project utilizes the same software to design for additive manufacturing.
To further reduce the barrier of entry to lost foam casting, researchers are also looking at eliminating the need for tooling altogether by directly printing the patterns. Castings could be ready in hours without expensive molding equipment. The industry has produced castings on a test basis successfully in bronze, aluminum, ductile iron and grey iron. Carbon and stainless steel are next.
Click here to view in the August 2020 digital edition
