Remote-Controlled Demolition Robots Quickly Provide ROI
On the surface, remote-controlled demolition robots can seem like a significant capital expense, but some operations have seen a return on investment after using a machine for just one kiln tear out. The versatile equipment speeds up refractory removal and cleanouts compared to alternative equipment for kilns, ladles, furnaces, castings, cupolas, runners and more. The machines also improve worker safety and free up resources for more critical operations in the plant.
Here are a few reasons foundry and mill operations choose to use a remote-controlled demolition machine:
More than a One-Trick Pony: Unlike some specialized, inflexible equipment meant for removing refractory in only specific applications, demolition robots are flexible for a variety of tasks. The machines are equipped with a three-part arm design which allows for precision and optimal power, whether it’s needed straight ahead, above or below the machine.
Free Up Resources While Working Faster: Refractory removal and similar jobs have traditionally been accomplished with handheld tools, such as jackhammers or rivet busters. This type of equipment depends on the person holding it and there’s only so much a laborer can do before tiring out. A demolition robot never tires. Remote-controlled demolition machines also allow operations to complete projects with fewer people, freeing up workers for other tasks. A Midwest foundry removing old refractory lining from iron pouring ladles saw a 75% increase in productivity by switching from handheld tools to a demolition robot. They went from using two workers over a period of 16 hours to a single operator and machine taking two hours.
Save on Workers’ Comp: Injuries happen. But they happen less when you remove workers from dangerous situations. Remote-controlled demolition machines allow operators to stand safely away from the danger but close enough to have a clear view of what’s going on.
Instead of exposing laborers to the risk of falling debris, a hardened robot takes the impacts. Additionally, demolition robots can endure high temperatures, extreme levels of dust and harsh chemicals. Operations have seen as much as 50% savings in workers’ comp as a result of using robotic demolition machines.
When it comes to maintenance equipment for hot applications, remote-controlled demolition machines might seem like a big investment at first, but the versatility, efficiency and enhanced safety they provide quickly adds up to significant ROI.
This article was written by Lars Lindgren, president of AFS Corporate Member Brokk Inc. (Monroe, Washington). Brokk is a manufacturer of remote-controlled demolition machines. Lindgren has more than 24 years of industry and leadership experience.
Click here to see this story as it appears in the October 2019 issue of Modern Casting.
